its me again going on two months now 90 blue festy still won't start fuses are good . with the key on the pump don't kick and the coil don't fire the tilt switch is good and the fuel relay is good i'm out of ideas. this is a stumper
new brain still no fire or fuel Help
im a bit confused
the fusable links are good? if you didnt check them with a multimeter just to be %100
is there power to the coil and uel pump when u turn the key on? i know you said they didnt kick but im asking about voltage.88 mustang 427 stroker garrett t-76 turbo best run 8.86@ 151.56
91 red gl festiva the $50 daily driver <--toast
WANTED 78-80 FORD FIESTA (PREF GHIA)
Are you sure you have fuel pressure at the engine?
Do you have spark? if not then maybe your distributor is bad?
See if the roll-over switch is tripped in the back driver fender first.... If that's not tripped pull the hose at the engine and crank for fuel to rail. Not present bench test the fuel pump. For the spark check your coils and the crank pick up in the disty if coil has power.---------------------------------------------------
Went back and read your other thread.
After you recheck fuses etc....
I would check for power to the computer "brain" if nothing take a look at the ignition switch and wiring. Make sure the brain has proper voltage with key in run position and while cranking.
Check the wiring at the brain plug to be sure all pins are well seated and making contact, sometimes they push out when plugging it in.Hotrod Forums Directory * D&D Discbrakes 61-67 Econoline Conversions
volts good just noticed that the motorized seatbelts don't move ether when turning the key or in on posotion would the seat belt box under the seat keep it from firing? and how do i check power to the box which wire saw a post some where about a guy who had a blue wire from the brain go bad took him months ps so lost
Taking a peek at a wiring diagram for a 90 L shows a RED wire that is between the fuel pump inertia switch and the pasive restraint module. Not sure if its recieving power or sending.
The power wire for the restraint module should be yellow, comes from a 30A fuse labeled "Belt".
On your ignition switch there should be power at the White and the White/Black wires when in the run & start positions if not this maybe the issue.
Please, someone step in and correct if any of this info is wrong, going off of mitchell.Hotrod Forums Directory * D&D Discbrakes 61-67 Econoline Conversions
no
