my 88 just started to run rough . seems like only in the bitter cold weather.i take care of this car. it got down to 6 degrees thats when it started. today was around 28 degrees. still the same rough running i can hear thru the exaust. any ideas ?
88 festy carb
Does it run rough only when you first start it, or all the time?http://www.cardomain.com/id/hawkdoc60
Condensation in the tank causing water in the fuel. Drain the tank, (there's a plug in it), Dump new gas in, keep your tank above half full in cold weather, and run gas line antifreeze. Follow the instructions on the bottle. I use 1 ever second tank usually.Of course the red makes it go faster..
carb
[QUOTE=hawkdoc60;198666]Does it run rough only when you first start it, or all the time?[/QU i keep my tank full most of the time. the last time i drove it it was running rough then all of a sudden i put it in second gear and drove it for a bit then there was like a surge and the roughness went away. could be the freeze. i will put some anti freeze line in thanks
Carb
[QUOTE=ch33z3x;198812]Condensation in the tank causing water in the fuel. Drain the tank, (there's a plug in it), Dump new gas in, keep your tank above half full in cold weather, and run gas line antifreeze. Follow the instructions on the bottle. I use 1 ever second tank usually , i have the festy running now ran rough at start up. moving it around the yard trying to iron it out. next chance i have i will get some anti freeze for the tank. thanks
Yutz,
Any reason why your shouting your replies to hawkdoc60 and ch33z3x?
Otherwise, please edit your posts.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Yutz,
It's not a crime!
Just wondered if there was a reason.
Please check your PM.'93 Blue 5spd 230K(down for clutch and overall maintanence)
typically OEM champion 64 or NGK's I think, but that might only be for EFI.
If you have the original hood there is a sticker on it and should give the suggested plug and gap for the vehicle.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by WmWatt View PostGas line antifreeze?
Isn't that ethanol, what they put in the fuel by default?
Does is make any difference to add it now?
But it should help absorb water and get it through the fuel system, if that is the issue.
Methanol (typical gas antifreeze) and Isopropanol (Seafoam) are better.
That said I think you are correct WmWatt.
I would use a carb/injection cleaner like Seafoam in the tank for the next few tanks and see if that helps.
He may have already found part of the answer with the "gunked up" plug.'93 Blue 5spd 230K(down for clutch and overall maintanence)
