Sorry to dig up an old thread but I'm having similar issues. However I have NO power, I haven't checked at the room fuse but at the external fusible link holder, I have no power. All my fuses are good. Got power from batt to starter just not anywhere else.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
which wire is that? i have no wire that goes from my fusible links to the battery,there's two white. one runs from the ALT all the way back around to a relay on the PASS. side, the other leads to the same relay and goes to the MAIN fuse link on the "block". in that same relay there's a red with yellow and a big red/black i believe. if i run a jumper from the batt to the ALT. it will crank, dash lights work, but no start, and no headlights. EGI fuse has no power on the "block".
My bad I was looking at my custom stuff, I had a h20 generator.
Look at nitrofarms signature it shows the trouble spot at the links.
Bad news spot, fix it up like new, more than one way to do it is detailed
on this site, pick one and fix it. Cut the darn box out and rewire from scratch
It looks like you have one wire going to the starter but there are two
probably black wires, one goes to your links box. Jumping what you did
proves the box is burnt out. easy fix...
