I have to replace my heater core and I'm not liking what I'm reading in either the Haynes or shop manuals. Both say that the entire dashboard has to come out. Has anyone changed their heater core with the dash in?
Thanks
Ian
You can get the motor out without taking the dash out. But for the core itself, having taken it out myself, sorry to tell you, but you have to take the dash out.
I'm going to tackle this job next weekend. While I've got the dash out I'll clean out all the ducts, install the B-Quiet (similar to Dynamat) stuff I picked up a while ago and install the air conditioning I've had sitting in the garage for the past year or so.
If anyone has any tips on this whole process I'd really appreicate it. I'll try and remember to take pictures as I go along too.
Thanks
Ian
Yeah, the dash definitely has to come out. Definitely do-able in a weekend though. If I recall I did my heater core and installed my remote start while I had my dash out all in one weekend.
Suggestions? Have no mercy. Remove EVERYTHING, it will make your job easier. Definitely remove the steering wheel.
I think there is a bolt on each side ontop of the dash under the covers, plus one in the middle behind the clock. Plus one in each door jam behind the covers. And one on each side beneath the dash (hood release area). And I think there might be one ore two in the middle behind the center console. But thats it.
I'm going to start work on this tonight. Would it be worthwhile to pull out the front seats to provide more working room?
Ian
Well, stage one is complete... the dash is out. I was pleasantly surprised in that it only took me 90 minutes. Next step... pull the heater box and switch out the heater core.
Ian
