Well, I'm still trying to get the old one out. There's some sort of sensor at the bottom of the radiator with 2 wires going to it. Is that something for the A/C? I don't see a spot for it on my new radiator. Am I completely screwed?
Need Help Replacing this radiator
my situation was opposite of yours, i had a stock radiator without that switch and wiring and my new radiator had it.. it is unplugged now. Carbed cars have it, FI ones don't.
check out this thread:
-Aspire brake swap COMPLETE!
someone else will have to chime in, i don't know.
will the plug thing not just screw out? it looks like its threaded. if you can't get it out from the bottom, you could just cut the wires, get the rad out, and then splice them back when you get done. i'll look in the ford manual and see if i can figure out what the thing does. its gotta be in there somewhere.89 L, hopefully returning from the dead soon with a little more power... :twisted:
It will screw out.If yours is like mine the wire connectors are corroded and will not come loose. Best, in my opinion is to cut the wires or you will damage the switch. THE switch has nothing to do with the air conditioner. It is a radiator temp. sensor. My 1989 Festiva has air and the sensor is not connected and the car runs as good as my 1988 which has no air and the sensor is connected. From what I can tell, the sensor may send a signal to the ECU for some reason, maybe for some emmision control.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
you need that switch. It's not "just for emissions..." It's the Coolant Temperature Switch, and tells the ECM when to reduce the idle speed, after the engine approaches operating temp. Without it, the engine will either idle rich all the time, or be hard to keep running when it's cold (less than 70degF), depending on wether or not the wires are left open or shorted together.Jim DeAngelis
kittens give Morbo gas!!
Thanks Jim, I have noticed that the 1989 does idle very low till it warms up.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1991 s-10
Originally posted by FB71 View Postyou need that switch. It's not "just for emissions..." It's the Coolant Temperature Switch, and tells the ECM when to reduce the idle speed, after the engine approaches operating temp. Without it, the engine will either idle rich all the time, or be hard to keep running when it's cold (less than 70degF), depending on wether or not the wires are left open or shorted together.
VERY interesting... My 88 has the switch, but the connector is busted an there for the switch is not hooked up. BUT my car warms up and then the idle kicks down, just like any other electric choke carb.
Are we sure that is what this switch does?Previous owner of a '89 Graphite L, 4spd, GL Seats, Aspire Brakes, 14x6's, 185/60/14's
Originally posted by jasonpaulbauer View PostVERY interesting... My 88 has the switch, but the connector is busted an there for the switch is not hooked up. BUT my car warms up and then the idle kicks down, just like any other electric choke carb.
I guess I need to clarify that statement. It doesn't control cold idle kickdown to curb idle, that's handled by the choke stove (heater) and the ECT (Engine Coolant Temp sensor, separate from the CTS). This switch tells the ECA to turn on or off airbleeds (the ABCV stepper motor) to provide additional enrichment during cold engine operation. If left in one state, the engine will always be rich, gradually loading your catalytic converter (which gradually leads to failure), increasing your exhaust emissions and reducing your fuel economy a bit. If left in the other state, the engine will be lean during cold operation, potentially causing driveability issues, including a low idle speed.
The difference in idle speed I'm refering to is maybe only 150rpm.
88FestivaLX, I would just epoxy the switch to the outside of the bottom tank. It'll take the switch a bit longer to warm up, but you shouldn't notice any real issues, especially in GA. The worst that will happen for you is that runs a bit rich for a few minutes after it warms up.Last edited by FB71; 01-28-2009, 02:48 PM.Jim DeAngelis
