This is from my other thread asking about the filter. I got a new breather filter, out it in and drove about 20 miles. Got home and checked it and the filter is wet with white crap again. The PCV valve is too. It doesn't smell like coolant. It just smells like oil and gas to me. What could be the problem? The hose from the valve cover to the air cleaner was full of white gunk also.
Ok, somethings not right
Mine gets it also and has it now, also my S-10 pick-up. Mine is only in the PCV and oil filler cap on both vehicles. We have been having some tremendous temperature extremes lately and i have been driving mine on just short trips not heating up the engines to operating temps for long enough to burn off the moisture caused by condensation. This could be one reason.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
Originally posted by 88FestivaLX View PostWell, I've been driving it about 75 miles a day1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1991 s-10
Mark your over fill tank, and keep and eye on it and me thinks you notice a drop!
Especially, at 75 miles a day 375 miles a week!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Kind of sounds like a blown head gasket. Try changing the oil out and looking/smelling for coolant. If its not the head gasket there is some other coolant leak into the engine. Could be one of the many cooling lines for the throttle body, IAC, etc. Check all your cooling hoses and make sure none of them are leaking into the engine."If you're not first you're last!" -Ricky Bobby
-91L "Oliver" Now B6DE swapped with an ATX Capri ECU on a MTX!!!!
The little Festy that could...and did!
(Gone on to a new life)
-90 Ford Bronco II Eddie Bauer
Originally posted by SIBladerunner View PostKind of sounds like a blown head gasket. Try changing the oil out and looking/smelling for coolant. If its not the head gasket there is some other coolant leak into the engine. Could be one of the many cooling lines for the throttle body, IAC, etc. Check all your cooling hoses and make sure none of them are leaking into the engine.
Is there any kind of additive or anything I should run through the oil or gas? Actually, 2 tanks ago, I ran a bottle of Lucas in the gas.
Originally posted by 88FestivaLX View PostMy car is carbed.
Is there any kind of additive or anything I should run through the oil or gas? Actually, 2 tanks ago, I ran a bottle of Lucas in the gas.Jim DeAngelis
kittens give Morbo gas!!
Originally posted by FB71 View Postchange the oil, and add 1/2 can of Seafoam to the oil. Drive it for a few days, clean out the breather, and see if it helped. If my suspicions are correct, it won't, unfortunately...
-Aspire brake swap COMPLETE!
Well, I pulled the dipstick when I got home....its covered in white sludge.....I give up. I've been waiting since September to fix the suspension on it and something always comes up.Last edited by 88FestivaLX; 02-06-2009, 11:56 PM.
