...and I need input from you experienced mechanics. If you've kept up with my saga you know I had to replace the head. Put in new VCG and all new seals. Put in a new PCV valve but when the mechanic who did the head replacement took the new PCV out he laid it on a hot part of the engine and the back side melted. Didn't catch it until the pressure built up and blew the gasket again. Replaced the gasket and also used sealant per advice. Replaced the PCV (again) an no leak for 3 weeks. Now leaking again.
When you're looking at the engine the leak is coming from the front right corner. That seems to be the only place but the oil is coming out in a steady stream. With a new head I don't think I will ever find an older VC that will match perfectly. I really do not want to replace the VC if I don't have to. Any suggestions on how to stop this leak?
. Took the air intake tube off the TB and adjusted the fitting, replace it and got Hot Rod running. I'm still hearing a sucking noise but think I know the cause. Where the tube connects to the TB there are plastic teeth on the end of the tube. One of those was badly bent and I removed it to keep it from getting inhaled by the TB. I'm pretty sure that is where the noise is coming from. Got to find a new tube now.
