Is there any way to check the ecu codes? Like on the escorts, and hondas i could use a paper clip to jump the connection and the check engine light would flash out the codes. Im wondering how to do this on my festiva. thanks
how to check cel codes
Help us out. What year Festy? Fuel injection or carbed? Where are you located (put this in your profile)? If fuel injection go to the search engine at the top right of the tool bar and key in "Trouble Codes". I put a detailed explanation there a few weeks back. Search is your friend
'93 Festiva GL / "HOT ROD"
'02 F-150 Supercrew
'02 Excursion 4x4
'98 Jeep Cherokee Classic Limited
hey buddy, do you know how to search? its the button in the blue bar on every page....it'll help you in the long run.. i searched as stated above and found it...Originally posted by 187festiva View Postits a 90 L plus. Thanks for the info, does anyone have a list of what the codes are?
now you do it, i'll give you a hint (thread 5940) it has 2 pages from the manual scanned for carb and efi on the codes...
-Aspire brake swap COMPLETE!
im not your buddy chill outOriginally posted by ejp2fast View Posthey buddy, do you know how to search? its the button in the blue bar on every page....it'll help you in the long run.. i searched as stated above and found it...
did you find it?
same..
You guys are killing me:p Just so you know where the sarcasm is coming from we have people asking the same questions on here all the time and we answer them over and over again. Usually the questions come from the new guys and we harrass the snot out of them until they use the search tool. That one tool has been of more use to me than anything in my tool box. If you've done a search and can't find what you need then post. In your post note that you've done the search and couldn't find what you're looking for. You will find quickly this is the BEST bunch of folks when it comes to real help.Originally posted by 187festiva View Postits ok ill call nasa and see if i can use the hubble to read them'93 Festiva GL / "HOT ROD"
'02 F-150 Supercrew
'02 Excursion 4x4
