I was talking to a friend last night and they mentioned that their festiva was acting up. They said they went to start it the other day and the oil light stayed on and the engine was making alot of upper engine noise. They said they turned it off right away and checked the oil and the oil level was full. Any ideas on what is wrong or what I can check? Can an oil pump just all of a sudden fail like that or are their other issues?
oil pump question for a friend
The Festiva Store
Specializing in restoration, tuning and custom parts.Tags: None
Actually, I believe an oil pump can indeed fail suddenly. There is also the possibility there is foreign matter in the system plugging something up. I believe FB71 would bve able to say better.http://www.cardomain.com/id/hawkdoc60
Not familiar with the oil pickup on the festiva yet, never needed to drop the pan yet!
I suspect it is possible, as hawkdoc60 said, to have a blockage that keeps oil from moving from the pan to the pump or that the shaft to the pump has failed.
Otherwise I'd expect a gradual lose in oil pressure as the pump itself looses clearances, not an abrupt failure.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by FB71 View Post^^^ correct. Also, there is no shaft to drive the pump. It's driven directly off of the crank snout.
Don't have manual handy, so how is the pump coupled to the "crank snout"?'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by j-stauf7 View PostAssuming that their actually is no oil pressure, i.e. pressure sensor is ok, your most likely going to find a blocked oil pick up or a faulty oil pump.
Originally posted by Pu241Don't have manual handy, so how is the pump coupled to the "crank snout"?The Festiva Store
Common problems to any oil pump is that the pressure relief internal to the pump failed or the sump screen is clogged. In either case, the pan wiil have to be dropped to look further.
In the festiva....a cotter pin holds the pressure relief in place. If the pin...or spring...or seat internal to the relief failed; oil pressure will be lost.
Also....excessively worn rod or crank bearings can cause a pressure drop large enough to force the light on and not supply enough oil tot the upper end causing all of the noise.
Alot of noise....oil light on....oil in the pan...is not good. May be an easy fix but be advises...the engine is not far from self destructing.Joe Lutz
The SKATE ..... 1992L 5spd
Sending unit is between the pimp and filter....back side of the block under the intake manifold.
If the filter clogged...the head would make noise but the oil light would not be on.
If the filter failed open inside the pump should still be suffice on flow and pressure...the restictions in the circuit that creat pressure....are down stream of the filter.Joe Lutz
