Adjusting the throttle cable
  • Adjusting the throttle cable
    I was wondering if over time and lots of miles if the throttle cable stretches and would need to be adjusted for better throttle response? My car feels like the gas pedal travels a little further to start accelerating. Once its up to speed, and pulls hard and reaches 55 mph pretty easily. Just getting off the line it seems like it takes a while. I have an 89 L with 184,000 miles on it and it starts right up and idles like a Rolex. Have any of you adjusted your throttle cables? I've seen instructions on how to do it in the Haynes manual.
    Semper Fi til I die!
    1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
    Before you "adjust" anything, see if you have slack in the throttle cable.
    I've needed to adjust more than a few, but only if they needed it!
      agreed, see if there is slack.... they are pretty straight forward to adjust.
      -Aspire brake swap COMPLETE!
        Reach into the engine compartment, grab the trottle lever, and see if there is any play there.
          Sluggish acceleration.....poor base timing or a shot rotor and cap.
          Joe Lutz
          The SKATE ..... 1992L 5spd
            Cap, rotor, plugs (NGK V Power) and wires are all brand new. I was gonna do the base timing next. Thanks for the advice and help guys.
