Most noticeable in 4th gear at low rpm. If I am off the gas and go to give it gas, it get a little burble then it goes just fine. I did plugs, wires, cap and rotor, and finally new fuel filter. I cleaned the carb out a little bit and sprayed some cleaner though the gas line when I was doing the fuel filter.
I know the air temp sensor is broken in the air filter housing but as some one stated that is primarily for warm up(check other thread). I think a new coil might fix it, or rebuilding the carb (really want to avoid that). I adjusted the timing and it is actually +2/+3 advanced. Any other suggestions?
Thanks,
Ian
Thanks,
Ian
