got fuel at the injectors fire at the plugs & comprestion the exshuat is not stoped up ?????????????????
still no go
timing
check your cam timing and your ign timing, also, what does your spark lool like? orange or bright blue?Trees aren't kind to me...
cam timing is a physical check, do it with the upper cover off.
fuel pressure is...? should be around 36psiTrees aren't kind to me...
if there's compression, there's airTrees aren't kind to me...
honda? i don't touch the stuff. and i see where you are going w/ the "air" comment nowTrees aren't kind to me...
Hmmmm...what's the original problem?
Timming? Just beacuse you have spark does not mean it's at the right time....then again....just off a little bit should create some backfire.
Maybe to much or to little air...if this is the case...for an FI...at least it should start but not stay running.Joe Lutz
The SKATE ..... 1992L 5spd
make sure your cam is on the compression stroke when cyl 1 is at TDC and double check your rotor position on the distro. once all this is confirmed and you can verify good spark and injectors are actually flowing fuel, the car should run barring any ECM problems.Trees aren't kind to me...
I would double check evrey thing.
If you have fuel and spark and as Festyboy most correctly said where there is compression there is air...the car should start...if the timing is off the car will run like dung but still run.Joe Lutz
