hey whats a good belt to buy i got one from napa about 1000 miles ago and it sqweels like crazy
Belt Q?
Belt Q?
Frankie
fully custom 88 festy (project doomsday) Febuary in 2012 calander
Blockspire: ken block replica aspire
AdvancedDynamix: "If you put the same kind of effort into your engine that you put into the rest of the car, well... it'll be epic". thanks man
http://www.facebook.com/#!/profile.p...00000110128487Tags: None
i'd first check that it has the proper tension..
-Aspire brake swap COMPLETE!
it had great tension but after about a month or so it gets this really bad skweel right when it starts up i try to rev it away and it eventually works but i just wanna know whats a good aftermarket belt to get for itFrankie
if theres oil on the belt it will sqwuack
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
Originally posted by ejp2fast View Posti'd first check that it has the proper tension..
I've always used NAPA or CarQuest belts without incident.
Every time I change a belt I clean all of the V-grooves with a little solvent (laquer thinner) and Scocth-Brit. If it's the belt...it is because it glazed...because the tension was insufficient or a bearing went bad....maybe to much tension.Joe Lutz
The SKATE ..... 1992L 5spd
thanks guys i fixed it with a little more tension if i have the prob again ill make sure i clean the pully extra good next time laterFrankie
Originally posted by CharlieZ View PostA belt of Jack Danials once in a while works too.
