thanks FestYboy, i'll try there first. hey , does anyone know if all the #s Chuck posted are 2 stage stats? cheers
coolant mystery
picked up the right tstat from mazda... 5 min from home my mcparts one starts working! think im gonna switch it anyway new head gasket and all...light a man a fire and he'll stay warm for the night.
light a man on fire and he'll stay warm for the rest of his life.:faroah:
Yes, those part numbers are dual stage t-stats.Originally posted by blue*93 View Postthanks FestYboy, i'll try there first. hey , does anyone know if all the #s Chuck posted are 2 stage stats? cheers
-Aspire brake swap COMPLETE!
hey, when installing 2 stage t-stat, would the subvalve be top middle, or the little bypass hole? haynes says bypass on older, valve on newer. bypass has arrow pointing out, valve is centered above spring valve like so
muchas graciaslight a man a fire and he'll stay warm for the night.
i think i installed mine with the small valve on the side, and the bypass hole on top.. like the 2nd picture.
yeah thanks ejp just found a thread 'bout it, apparently it's all good ass long as the bypass (little valve) is in the top half, ftr. i think i'll put it... 3* right of tdc... no better make that left
man does that tstat ever make a difference! i get heat in -30 in minutes! no more oil in my coolant either. temp. is holding at normal. all in all- great success (so far)
cheerslight a man a fire and he'll stay warm for the night.
yep! extracting every joule of heat from these cars is worth it! especially where you are at!
