I've done the search thing and see where heating the studs with a torch to loosen them has been suggested but haven't seen anything about success. Has anyone done this and if so were you successful? I can't get the dang studs loose on my 93. I've used PB Blaster to no avail. Tried the breaker bar with no results. Heat seems to be the only solution but are their drawbacks?
Thanks
Thanks
