I was looking at a 88 festiva today, it was a 5 speed, The guy who owned it said he had just put a new clutch in it, but now he had only 2nd,4th and reverse gear. Does anyone have any suggestions as to what he did wrong, or what happened? Thanks
Trans Problems
Did he have the problem before he changed the clutch? It sounds to me like there is a syncro issue or other internal problem with the gear train itself.http://www.cardomain.com/id/hawkdoc60
01 Chevy Impala 9C1 police package "Unnamed yet". 154K
88 LX 5 speed "Silver PHOENIX" Currently being rebuilt inside and out. 400K
88 L 4 speed "Cherry Bomb" saved from the car crusher just in time. 186K
06 Ford F-150 Pickup Replacement for my 2001 Impala Cop Car that lunched its engine.
You know, I wonder if he did not reconnect the rod that connects to the bushing next to the shift linkage.http://www.cardomain.com/id/hawkdoc60
Click & Clack used to say on even date drive with even gears...on odd dates drive with odd gears....in your case drive it every other day.
Some thing is wrong in the linkages....not connected...bent rod....strut nt in place...sounds like something simple.Joe Lutz
The SKATE ..... 1992L 5spd
The car can be driven with the clutch disc in backwards. I bought one last month and replaced the clutch after the previous owner put it in backwards. The clutch would not fully disengage, so it made it difficult to drive and I had to use the starter to get it going in first, but I was able to drive it 30 miles to my house.Originally posted by steelcurtain4386 View Postit CAN go in backward, but you wouldn't get ANY gears. probably has the linkage screwed up.The Festiva Store
check
Check to see if he bolted the shifter up properly to the clevis yoke on the transmission. The bolts are 8mm and sized to just stick out the proper distance for a few threads to prodrude beyond the retaining nut. There is not much clearance. I hope he didn't substitute any other bolt. Disconnect the shifter and see if you can get it into all 6 gears with a Robertson screwdiver through the holes of the clevis yoke. It should go easily into all gears. Good luck.
Don't forget about pushing in, just as you would with the shifter stick.
About that bolt. Does anyone know if ebay item #170304413571 will substitute?
Doe the original have bushings like these?Last edited by bravekozak; 02-28-2009, 09:59 PM.
i second the linkage issue...
-Aspire brake swap COMPLETE!
