Alternator whining
  • Alternator whining
    My alt. was loose after I was stuck in snow a while back.I raced it several times to try and get out.Anyway,it needed tightened after that.Now it whines.Not seemingly in a bad way,but,really,it sounds like a racing type of sound .Anything to worry about ?
    Maybe too tight!
    Can destroy you Alt bearings if you have it overly tight.
    When was last time your ALT belt was replaced.
    Note ALT belt also drives Coolant pump, a very necessary piece of equipment.
    Lose you ALT belt and your car will over heat, with the attending great possibility of warping the head and blowing the head gasket.
    Don't ask how I know!
      I will change it.ASAP.
        are you sure its the alt winning and not the waterpump?
        88 mustang 427 stroker garrett t-76 turbo best run 8.86@ 151.56
        91 red gl festiva the $50 daily driver <--toast
        WANTED 78-80 FORD FIESTA (PREF GHIA)
          I would think it is the alt., since he tightened the belt and the noise started. I have had that happen. If the belt gets a little wet it seems to me like it does not take long to go to crap. I have had this happen several times. After a couple squeels it is gone and tightening it has just lead to whining in my alt also.
