hello there. does any one know a good way to tighten valve cover bolts? my manual says 44-80 inch pounds but i only have ft. lbs torque and no 1/2 10mm plus a few ft lbs doest seem tight enough for a major engine part. cheers
valve cover bolts
hand tight, and DON"T crank on it. i use the wrist method: tighten with fingers till you can go any more and give it one good twist with the WRIST (not arm). it actually gets it pretty close.Trees aren't kind to me...
good to hear!Trees aren't kind to me...
