hey i met this guy today that had a problem with his festiva, he dosnt have internet so im posting the question for him. he has a 90-93 auto festiva, i think its a 91 but not to shure... anyways, he said that the 3 jumper wires under the hood by the drivers side strut mount burn up. they get hot and start to smoke and burn up... he replaced the computer and that didnt solve it, no he is kind of lost... any ideas? im kind of thinking that the wires leading up to the jumpers are shorted/ grounded out. anyone else have this problem? also i still dont even know what they are for... lol. what the heck do they do?
jumper wires burning up.
Mike, AKA the sasquatch
1990 LX, bp+T/g25mr, 9psi dynoed at 194HP, turbonetics t3/to4e 57trim, haltech E6X standalone, 550cc injectors, turbosmart wastegate, synapse BOV, walbro 255 fuel pump, aeromotive FPR, AEM wideband, 3 inch exhaust, huge FMIC, 9LB flywheel, 6 puck clutch and way more parts that im forgetting i installed lol...Tags: None
ok ill try that. thanks for the input. but, if anyone has any other ideas please let me know.
check his fuses in the fuse block (in dash), he may have the wrong values there. also, are all 3 burning up, or just one? you can do a draw test by placing a test light between the positive terminal and battery post; with the Ign OFF, start pulling fuses in the dash block untill the test light goes out, the last fuse you pull should be the system you focus on. repair the issue and test again.Trees aren't kind to me...
Originally posted by FestYboy View Postcheck his fuses in the fuse block (in dash), he may have the wrong values there. also, are all 3 burning up, or just one? you can do a draw test by placing a test light between the positive terminal and battery post; with the Ign OFF, start pulling fuses in the dash block untill the test light goes out, the last fuse you pull should be the system you focus on. repair the issue and test again.
Originally posted by FestYboy View Postcheck his fuses in the fuse block (in dash), he may have the wrong values there. also, are all 3 burning up, or just one? you can do a draw test by placing a test light between the positive terminal and battery post; with the Ign OFF, start pulling fuses in the dash block untill the test light goes out, the last fuse you pull should be the system you focus on. repair the issue and test again.ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
Originally posted by leapin View Postis his aqua too? older fellow? lives on 32 ave? if thats the case hes got quite the car...ive met him a handful of times.
Originally posted by leapin View PostI would guess some of his problems stem from his manual to auto swap. By the looks of things all he did was swap the tranny. He says he has to push in the clutch to start it still! the car is kind of a mish mash of two festivas.
