Well my sister showed up at my house and almost hit my festy because her brake line rusted through... so my question is when I put a new brake line on (its to the right rear drum) will i only have to bleed the drum, or will i have to bleed it all?
I think you can get away with just bleeding the 1. But itd be wise to just do them all to be safe. Might want to check the other line while youre at it. If 1 has went bad the other may not be in very good shape either.
- Unknown
- Quentin Crisp
- Bumper Sticker
You should bleed them all...it's always hard to determine how much air got sucked into the system....make sure you keep an eye on the reservoir level while bleeding.
Joe Lutz
The SKATE ..... 1992L 5spd
Ok, I might just bleed the one for now, and I also checked all the lines for corrosion to find anymore possible leaks in the future and all the lines look decent except for the one that rusted out... it was along the frame and look as if this specific spot got all the water's attention while driving lol
01 Chevy Impala 9C1 police package "Unnamed yet". 154K
88 LX 5 speed "Silver PHOENIX" Currently being rebuilt inside and out. 400K
88 L 4 speed "Cherry Bomb" saved from the car crusher just in time. 186K
06 Ford F-150 Pickup Replacement for my 2001 Impala Cop Car that lunched its engine.
If the right rear is the only one to show signs of rust it is more than likely from an exhaust leak in that area at some point in time. If I am correct the exhaust pipe runs very close to the brake line and has a bend there as well, very common area to rust out.
The combination of moisture, exhaust gasses and heat do some nasty stuff.
I agree with the flushing of the brake fluid, a very over looked fluid in most cases.
