Disabling fuel pump
  • Disabling fuel pump
    92 ATX
    There is no fuse marked "Fuel Pump." The fuel pump relay and connector are about 10 feeet up and under the dash panel. Is there a way to disable the pump during compression testing etc.? Does the pump share a fuse with something. If so, that makes me think, What the...? There is the inertial switch in the rear of the car. I guess disconnecting the plug at that point would do it. Any ideas?
    Thanks.
    Think just engaging the inertial switch will do it!
    A good whack should do it.
      ^^^ That "whack" you suggest, you do mean to the switch, right? LOL
        Yes, a "whack" should enage the switch, no need to disconnect it!
          for curiousity sake, how do you just whack it? does it matter which way you whack it?
          -Aspire brake swap COMPLETE!
            Don't use a BFH!
            I would think a rubber mallet would do the job.
              A pair of wire cutters at the fuel pump would work, too. LOL J/K Seriously, isn't there a plug on the top of the tank at the pump/fuel sender plate that could be disconnected?
              http://www.cardomain.com/id/hawkdoc60
              01 Chevy Impala 9C1 police package "Unnamed yet". 154K
              88 LX 5 speed "Silver PHOENIX" Currently being rebuilt inside and out. 400K
              88 L 4 speed "Cherry Bomb" saved from the car crusher just in time. 186K
              06 Ford F-150 Pickup Replacement for my 2001 Impala Cop Car that lunched its engine.
                yeah i do believe i remember a plug being right above the plate...or was it below it...
                also if you're worried about breaking the inertia switch by hitting it you can remove the two screws and shake it....or as mentioned before, simply unplug it
                Joey Richard Jr.
                1991 Ford Festiva L; died but donated all her organs
                1988 Ford Festiva LX; EFI swapped in...actually everything swapped in
                Quality is Job 1. Together, We Can Save Lives. Ford.
                  a strong thump with the bottom of your fist should trip the inertia switch.
                  Jim DeAngelis
                    How is the inertial switch reset after the thump?
                      Well, if the switch is anything like the cop car I've been working on then its just a button you push back in after you've tripped the switch
                        push in the button on the top to reset.
                          ^^^ correct
                          Jim DeAngelis
                            Hey....hey...hey.
                            Obvously we are trying to use the key switch to do the compresion test....is the coil disconnected!?!?!?. I not... it should be!!!!
                            If you do not have a remote starter....with a heavy gauge wire....14/12AWG...just jump the starter solinoid coil input to the + terminal of the battery...this way a compression test can be completed with the keys in your pocket.
                            Joe Lutz
                            The SKATE ..... 1992L 5spd
                              ^^ Yes, the connector was removed from the distributor. Couldn't locate the remote switch. It's here somewhere. <grin> I had a helper in the cockpit manning the key.
                              Thanks tho. That's good advice for anybody. Don't need any flash fires in the garage.
