92 ATX
There is no fuse marked "Fuel Pump." The fuel pump relay and connector are about 10 feeet up and under the dash panel. Is there a way to disable the pump during compression testing etc.? Does the pump share a fuse with something. If so, that makes me think, What the...? There is the inertial switch in the rear of the car. I guess disconnecting the plug at that point would do it. Any ideas?
Thanks.
Thanks.
