on my driver side rear wheel there is a problem that my friend found we were just standing around shooting the (edited for language - admin) cause I made a new exhaust for the festy(that is about 40db louder than annoying). so my friend kicked my back tire on the left side (closer to the drivers door) and the wheel moved then I kick the right of the tire and it moved back and we did this a few times and shared a good laugh about how my wheel is going to fall of on the way to work.
So... what caused it and how do I fix it? is it the wheel bearing? is it the whole spindle? I will be doing somthing about it tomarrow as I am pretty busy today. Also there is a festiva in my local wrecking yard should I just get the whole spindle off that and new bearings?
I did use search that is why I am sure it is the wheel bearing/spindle. But I did not find anyone with the same discription as mine as my festiva doesn't shake or anything like that when I am driving
any help is much appreiciated
AFTER
