Hi i have a festiva 5 spd and heres what happens When I drive there is a ticking sound BUT its tempo goes with the rpm the faster i drive the faster the ticking sound gets, I recently got my oil changed and checkd it and it was fine, it seems like its coming from the left side of the engine please if anybody can help let me know thankyou!
Please help!!
Sounds like a hyd. lifter didn't pump up after the oil change.
ChuckChuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
You need to have your oil pressure checked. It sounds like valve tick. If oil presuure is good, the valve lash may need adjustment.http://www.cardomain.com/id/hawkdoc60
01 Chevy Impala 9C1 police package "Unnamed yet". 154K
88 LX 5 speed "Silver PHOENIX" Currently being rebuilt inside and out. 400K
88 L 4 speed "Cherry Bomb" saved from the car crusher just in time. 186K
06 Ford F-150 Pickup Replacement for my 2001 Impala Cop Car that lunched its engine.
Back when I still had the b3 and I had a lifter stick, I got some Marvel Mystery Oil (comes in a red bottle) from the parts store. There are lots of other similar products out there that do the same thing. I let the engine idle for a while and get hot and eventually it cleared itself up. Make sure you don't overfill the crankcase too much and change the oil again when its done. If that doesnt help then you may need to get a new HLA (hydraulic lash adjuster)- long for lifter
alright thankyou i will check that stuff out,but i am really worried its a head or something thats going to cost alot of money,also it sounds like its coming from the timing belt/pulley system area,i drove it about 25 miles yesterday and it runs fine like normal but just a really loud ticking , would driving a few miles to work for a couple days cause damage cuz i am really need it to get to work and back until i solve this problem
thanks everyone
I looked into that i guess you can add it to your gas and oil? thanks i will try what you said i really hope this helpsOriginally posted by resuwrecked View PostBack when I still had the b3 and I had a lifter stick, I got some Marvel Mystery Oil (comes in a red bottle) from the parts store. There are lots of other similar products out there that do the same thing. I let the engine idle for a while and get hot and eventually it cleared itself up. Make sure you don't overfill the crankcase too much and change the oil again when its done. If that doesnt help then you may need to get a new HLA (hydraulic lash adjuster)- long for lifter
thanks again!
BEFORE you go adding things to the oil etc.... and looking at buying parts you really should run the car by someone that can physically listen to it and ask their opinion.
Not naming any names but another from this forum had similiar noises and started doing all sorts of stuff to the lifters and what not, after spending a good chunk of change he brought it by and I helped fix an exhaust leak at the manifold to head. Alot to be said when you can actually see and hear something before telling whats wrong.Hotrod Forums Directory * D&D Discbrakes 61-67 Econoline Conversions
thankyou yes i understand what your sayin but im just trying to get some ideas and what not so i have a better idea at the problemOriginally posted by econoaddict View PostBEFORE you go adding things to the oil etc.... and looking at buying parts you really should run the car by someone that can physically listen to it and ask their opinion.
well if it's not an EFI car, then it's an LX w/ mechanical lifters (adjustable).Trees aren't kind to me...
Add your location and maybe a member near you can help you figure the problem out.ENFORCER - Midwest Festiva Inc., Iowa
#2 .....Cheesehead
#3 '91 White - Donor Car
#4 .....Montana Project
SOLD----Levistiva for $1500
Bought her back for $450
