Swapping gauge cluster
  • Swapping gauge cluster
    I've been pinching my hand trying to pull the plug on the back of my gauge trying to get it out. I'm not sure how careful I have to be with it. I don't wanna wreck anything. Any tips from your experiences? I'd just rather be safe than sorry. I'm swapping our the standard cluster for one with a tach.
    If you're talking about the white and black plugs, make sure you lift that tab on the center of the back of the plug...it won't come out unless you do...after that a gentle pull or a not-so-gentle pull will do the trick.
    1989 Red L- The Baron
    www.letstalkbeatles.com
    Link to Baron Pics:
    http://s478.photobucket.com/albums/r...nmervap/Baron/
    1990 White GL- Chuck (for now)
      It helps if you unhook the speedo cable from where it connects in the engine bay to give you some slack
        Well thanks guys. I'll try that when I get back home. I can't see this stuff so I'm going by feel. btw I should have said plugs, ya, plural.
          Do what lane said...unhook the speedo cable at the tranny....then you can pull the speedo out far enough from the front and unhook the plugs....much much easier.
          Remember....if you are going from regular speedo to tach cluster you need to move the speedo cable to the other side of the support you will see when remove the speedo. Then there will be plenty of room and no kinking of the cable.
            ^^^^^What Geneva D said!^^^^^
            Link to Baron Pics:
              ^^^^^ What all of ya said! haha ^^^^^
                i found a nice little spot to reach up and un-hook the speedo cable from the cluster and from there you can easily reach behind the cluster to unhook the wires
                  Awesome guys. Got the new one in and took 150k off my car! heheh (km's btw). Thanks!
                    Good job! I found it to be remarkably easy by just following these guys instructions!
                    Link to Baron Pics:
                      Yes, for sure. It's so much easier when you've got the help from guys with experience. I love this site!
                        Ok, so I followed these steps, and my tach doesn't work. I put the white face (1990) cluster in with the tach, and it stays at 0. Is there an extra wire I need to hook up, and where would I get the wire and hook it up at? Thanks
                        My Fleet:
                          No extra wires. Possibly you have the plug not all the way on?
                            So, do you mean you found a place up behind the dash to reach up and unhook the speedo cable? Meaning you don't have to unhook it at the tranny?
                              I can unhook them without unhooking the cable from the tranny, done it 3 times that way now.
                              -93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
                              -85' Nissan Sentra 5 spd.
