Swapping gauge cluster
  • #31
    Originally posted by doylerl View Post
    Thanks for the tip on the speedo cable. I pulled it out no problem without unbolting it from the trans. again. FYI, upon further investigation, I discovered that my plug does not even have a wire and pin in the tach position. I will have to run a new one to the plug. I will let you know how it turns out. Thanks for the responses BTW.
    That's an interesting little bit of trivia, that yours didn't have the wire and pin. Never would have occurred to me. But I'm learning there are a lot of little inconsistencies like this from year to year, and in different trim levels.
    • #32
      Yea, I have noticed... I bought a hatch with rear defrost and rear wiper, but can't install them without a harness... no power mirror harness either... I have one of those now, but it is not installed yet. I don't know if it has to do with the year (1989), or if it is because it is the "base L model". Either way, it makes it difficult to add options.
      My Fleet:
      • #33
        it is weird cuz my 88 and 89 both have the defrost windows in them stock and his dont
