I just changed by rear wheel cylinder (along with front axles and emergency brake) and a very slow leak started at the fitting. . I redid the fitting and bleed the brakes again and still the fitting leaked. I just want to pass inspection so that I can do my aspire swap sometime this month. Would teflon tape work to stop the fitting from leaking?
I know that I put the fitting in straight. I plan on change the lines with the swap....I'm tired of borrowing another car to get back and forth from work.
Any suggestions??
Any suggestions??
