Not new to mechanics, but new to Festy and FWD transmissions.
I shifted it hard and it felt like it popped out of gear.
Now the engine runs great like it always has and shifts into every gear fine (shifter linkage is fine) but somewhere between the clutch and the axles power is not making it through
The speedo works and i can here that slight buzz of gears not quite meshing when it is in gear and clutch is out. so I'm thinking that whatever the gear between the diff and trans gears is called is the culprit.
Any educated info would be much appreciated before I dig in.
Thanks in advance.
Thanks in advance.
