I'm about to attempt two repairs I've never done. The first is pretty straight forward. [1] Replace a snapped e-brake cable. [2] Replace a worn bushing on the right front. I've emersed myself in the Haynes Manual so I'm good there but if you have any additional adivce or anything you think I need to know please chime in. THANKS
Advice for novice mechanic???
There both pretty easy repairs compared to a head gasket or something. What bushing are you gonna do?---------------------------------------------------
The one that separates the tie rod from the steering arm. I removed the passenger side wheel yesterday to see why I'm hearing popping when I make a strong left turn. The only obvious wear was this one particular bushing. It's shot for sure. Everything else looked good. I hope I'm calling this the right name.Originally posted by festivaWES View PostThere both pretty easy repairs compared to a head gasket or something. What bushing are you gonna do?'93 Festiva GL / "HOT ROD"
'02 F-150 Supercrew
'02 Excursion 4x4
'98 Jeep Cherokee Classic Limited
I guess the popping sound could come from the tie rod end if it is bad enough. It's CV joints that pop....replace half-shafts.Originally posted by BigWheel View PostThe one that separates the tie rod from the steering arm. I removed the passenger side wheel yesterday to see why I'm hearing popping when I make a strong left turn. The only obvious wear was this one particular bushing. It's shot for sure. Everything else looked good. I hope I'm calling this the right name.
Make sure when you remove tierod ends to mark the postion of the jamb nut, so it won't throw your allignment off.Last edited by festivaWES; 05-25-2009, 10:07 AM.---------------------------------------------------
