First,the a/c ...I bought a belt for the compressor and it looks like the compressor doesn't even go in line with anything else.Is there a trick to it ?/ Also,the belt I was sold by AZ looks too small..Also,how much should I put in the system once I change the fittings over ?
Second,coming back from Ohiostiva my car seemedto stay at 55 at one point.I floored it and it would not go any faster.I was going 70 earlier,so,it does go faster.also,it is an auto and sometimes you have to jiggle the auto on the floor(shifter) to get it in each gear.Would it be the cables ? Why would it only stay at 55 for a few while pressed to the floor ?
Also,I ran a high idle(IMO) all the way back.Over 3k rpm.
