A/C questions and Tranny probs,I think.Automatic
  • A/C questions and Tranny probs,I think.Automatic
    First,the a/c ...I bought a belt for the compressor and it looks like the compressor doesn't even go in line with anything else.Is there a trick to it ?/ Also,the belt I was sold by AZ looks too small..Also,how much should I put in the system once I change the fittings over ?
    Second,coming back from Ohiostiva my car seemedto stay at 55 at one point.I floored it and it would not go any faster.I was going 70 earlier,so,it does go faster.also,it is an auto and sometimes you have to jiggle the auto on the floor(shifter) to get it in each gear.Would it be the cables ? Why would it only stay at 55 for a few while pressed to the floor ?
    Also,I ran a high idle(IMO) all the way back.Over 3k rpm.
    Did you install the A/C or was it already there?
    There is a 2nd pulley that bolts to the crank, which drives the compressor. It isn't present on Festivas that were not equipped with A/C originally.
    I don't think your speed problem is with the transmission, although the shifter might be out of adjustment. My auto will easily go 55 in 2nd or 3rd gear.
    -Tim
    White '89L auto - Sold!
    Silver '06 Rav4, 95k!
      a/c looks like factory setup.came with car.I will try to post pics later.
        here are the pics...
          Def looks like you are missing the pulley that bolts to the crank to drive the compressor. Not to mention I don't see the tensioner there for the ac belt either.
          The new keeper of Uncle Fester!! 88 5-speed, efi, now with ac!
          1988 LX ~sold~
          1992 Blue GL auto, ac ~sold~
          2008 Nissan altima 3.5sl loaded <lease returned>
          1996 Nissan maxima <sold>
          2002 ford f350 crew cab short bed diesel
          Just remember, it could be worse, you could have a fork in your eye!!
            can I buy these at Auto Zone or Partsamerica or should I ask for them on here ??
              Whens the last time the fuel filter was changed?
              - Unknown
              - Quentin Crisp
              - Bumper Sticker
                Tony do you know if the engine was ever changed on the car? It seems that way. You neeed to go to the Festiva srap yard and get hose parts, I'd go with ya to make sure you get all you need because i need some trinkets myself.
                93 GL modyfied!!!
                :fish:
                  I think I might have that pulley in the parts pile.I can look today.
                    Well,Biglay,I can use it if you have it.Let me know.
                    Brian,I don't know if it has ever been changed.Would better pics help in telling if it was changed ??
                      Not really. But you do need some parts to begin to get it workin.
                      93 GL modyfied!!!
                      :fish:
