I am having "no spark" problems on my 91GL. There is no spark all the way back to the coil. What’s strange is that it starts sometimes but then runs real rough, and then it won’t start at all for the next several days.
I've checked plug wires, no spark...Wire from coil to distributor, no spark...Voltage to wire harness to coil = Ok.
What's throwing me is that it will start once every third or forth day, run real rough, then won't start for the next several days.
It seems like this problem started after it overheated one time. Could it be that the water tube that runs out of the overflow tank blew hot water onto the fuse links or something down in that area behind the driver’s side headlight?
