One of mine is cracked and I want to fix it before the winter. But not if I have to take everything apart to replace the boot. In that case its duct tape all the way. :lol: I appreciate any responses, fellow sh*#box owners
Are replacement split-style CV boots made for the Festiva?
If you catch the boots soon enough, the CV joint will still be good. I've changed probably a dozen boots on my Festivas. My first one had 280,000 miles on it when it left the family and still had factory axles. I have yet to hear a good report on any of the split boots. From what I've heard, they always leak so I would avoid these.
Duck tape isn't going to work either. Replacing the boots isn't hard, especially after you have done it a couple times. I can usually get it done in about 45 minutes. If you have a small crack and haven't lost much grease, replace the boots. If the hole is pretty big and you've lost a lot of grease, you may want to consider replacing the axle. New boot = 10-$12. Re-manufactured axle approx. $60.
I always check my boots for leaks every oil change and replace at the first sign of cracks.
split boots are pieces of junk. Don't buy them. Get the factory style replacement boot. You can get a good one with a lifetime warranty for $14.The Festiva Store
