i broke my festy again
  • i broke my festy again
    i was looking under my hood earlier and noticed a big wire connecting the starter to the solenoid was all burnt up so i pushed on it a lil and it broke.....
    oops
    so i bolted on a fresh wire to the solenoid and connected it to starter
    then i tryed starting it and the starter worked but it wont fire
    then...
    i ran a hot wire from my amp to the fuel pump under the back seat
    and it will start up with the hot wire attached but runs rough
    so im thinking it is something electrical right?
    91 L, 5 Speed
    90 323, auto
    Going from memory...The (+) wire goes from the battery to the solenoid...where it lands on the solenoid is anothe (+) wire that feeds the car....did you remember to also re-connect that wire...or if the one wire broke this one is probalbly pretty corroded.
    Joe Lutz
    The SKATE ..... 1992L 5spd
      the wires look good on the starter now.....
      its just the fuel pump isnt turning on when i try and start it
      i dont know why messing with the starter stopped the fuel pump from turning on..
      91 L, 5 Speed
      90 323, auto
        check you VAF, there's a fuel pump control (on/off) switch wire in that harness.
          its not the vaf i checked that
          its not getting any spark from the coil either
          91 L, 5 Speed
          90 323, auto
            It seems that you may have pulled a wire out and I am thinking it may be one of the wires on the coil, I have a carb model and it has happened to me so check the (-) terminal and my Festy has a blue wire and a yellow wire with a green trace, they are spade terminals so they can be easily disturbed, before you give up all hope make sure they are secure and also check the centre post on the coil for corrosion, also the centre post on the distributor, its the white powdery stuff that causes the problem....we spell center different from you guys, its just our flash way of spelling here in Aotearoa (NZ) :hello1:
            "all I ask is the chance to prove that money won't make me happy":simon:
              it was my ignition switch
              i jiggled it around a lil
              put my screw driver in and turned
              and it started right up
              91 L, 5 Speed
              90 323, auto
