ok, many folks over the years have had trouble with their beloved Festies not starting, or dying while driving. One of the possible failures is the distributor. I have devised a simple distributor tester.
It consists of the following components:
one 9V battery
one 9V battery clip
one LED, your choice of color. Just make sure it operates on 1.5 - 2.5 volts. 3.2v LEDS will be dim, unless you change the resistor value to 350 - 390 ohm.
one 1/4 watt resistor, 470 ohm (for 1.5V - 2.5V LEDs)
one distributor 3-wire connector from a junkyard Festiva.
Follow the wiring diagram below.
To test a distributor in the car;
this method assumes you have checked to see the timing belt is not broken, and the distributor turns while the engine is cranking.
Unplug the distributor connector from the distributor. Plug in the tester. Have an assistant crank the engine. Look for the LED to flash as the engine cranks. If it does flash, the distributor is good. No light or light solid = bad distributor.
To test out of the car;
connect tester to the distributor, turn distributor shaft by hand. Look for the LED to flash. Results same as "in car".
one 9V battery
one 9V battery clip
