EFI distributor tester
This is a sticky topic.
  • #16
    Just curious. My '89 FI AutoTrans died on me this morning and I happened to have a spare module (Igniter J 207) and when I switched to the new (actually, used but pre-tested as good) one the car started. Any way to test the old unit out of the distributor, and has anybody opened one up to try a repair/re-build of the module?
    After the first one failed on me a few years ago I tried to get one through a parts house, but it was a Saturday on a long weekend and they wouldn't've even been able to order one 'til the following Tuesday, and it listed for about 120 bucks. I hit a you-pull-it JY and got one for $5. I've since grabbed one every time I've seen it at a JY, and that's how I happened to have one in the glove box, and I know there's at least one more around somewhere, I believe in a toolbox in the garage.
    Do the later model AutoTrans models have the same module, or are they all the one that's part of the disty itself?
    Thanks.
    Rob J
    • #17
      Good toipc!
      • #18
        Thanks.
        Carb Festys are completely different and 89 auto Festys are a transition year but (solely for EFI Festys) I was told that rebuild kits for in-dizzie camshaft position sensors are not (and never have been) available and that you have to buy a complete new dizzie or have the old one rebuilt. On that note forum member Bobstad paid "full freight" at NAPA for one of these last year ($400 +/-) and that has prompted me to scour all 90-96 Mazda cars at JYs for these elusive (and now known expensive) dizzies. Whatever type of dizzies were used on EFI Festys are also common to many other Mazda pre-OBDII cars.
        It didn't bother me in the slightest at the U-Pull to have to fork over $10 for a virtually new dizzie plus cap and wires (wasn't even dirty nor the aluminum dulled) that I scored off a 94 MX3 B6 16 valve engine last spring.
        • #19
          Does anybody have the diagram that was in the original post?
          • #20
            +2 on re-posting the original wiring diagram. Technology is a fickle mistress.
            I am currently Festivaless. I am without Festiva. Non-Festiva. I'm UnFestiva'ed. Living post-Festiva. Ex-Festiva Life. Hashtag sad :'-(
            PS - Please send very low-dollar offers. Currently looking to buy, but will have to empty the couch cushions to do so. Hashtag sad, again.
            • #21
              I third that diagram summoning. 89 fi atx coil spark died on me two months ago. Took me this long to find you guys I must be losing my touch. Hello to all of you as well, so much awesome info.
              • #22
                Originally posted by FB71 View Post
                Follow the wiring diagram below.
                Do you still have the Diagram saved somewhere Jim?
                Will Samet
                How to find me:
                Feel free to PM me anytime!
                Instagram/Twitter: @WILLSAMET
                • #23
                  Any chance you could post the diagram of the disty tester again ?
                  186,000 miles per second is not just a good idea, it's the law
                  1990 yellow L+ (l8ly)
                  1990 yellow L+ (sunryz)
                  1992 aqua L (agua)
                  1993 blue L (aurora)
                  • #24
                    If I ever have another one go bad on any feisty distributor,I'm going to use a GM 4 wire module,coil and heat sink they will work with almost any trigger even points as a trigger.
                    • #25
                      I'm sorry didn't mean to discount your tester, just with 6 festys. 3 different distributor types a one size fits all solution is more practical for me.
                      • #26
                        where is the wiring diagram?
