ok i went to a jy and got another harness it was all good but the steering colum had been removed and they had cut all but one plug off. so i got it home and fix the harness and did the vics and the dist plug and added what was to be added for my bp and i put it all back in except the dash left it out and hooked every thing up and bolted the cloum in and turned the key and no fuel pump!!!(all grounds have been cleaned) and i still have the problem with the fan coming on insted of the lights but now i have turnsingals and i didnt befor? any ideas guys?? this crap is getting to me badly haha making very angry.
harness problem
well i was using the test light and found that my fuel pumps hot wire is running as ground and the ground is ground? and its never done that til i changed the harness. but i didnt mess with any thing back there. so yeah and my wiper motor is getting power to all the wires but one and they still dont work and same withe the lights but now the fan dont kick in when i turn them on?Last edited by hofficergrover; 06-21-2009, 03:16 PM.
you do realize that the fuel pump only turns on when the vaf door has been cracked open with the key in the run position..... right. its not like newer vehicles that turn on automaticaly until ample pressure is built up.
88 festiva lx, 2.3 turbo rwd swap in progress
1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
03' gt, full termi swap 700+ whp build
sponsered by,
pam pam's junk, dayton OR.
Bob's ok tires, salem OR.
Clausen Truckin', keizer OR.
try to just put power to the pump and just bypass all of factory wires, and see if the pump works. if it works then i would start tracing all the wires that go to the pump. i have done a harness swap from carb to efi and i know your frustration, i also tried using a butcherd harness and had alot of problems, but then i gave up and found a complete harness and the install was flawless and so much simpler!!
sponsered by,
yeah but my harness wasnt all messed up with any thing that went to the pump and if i just do that then the wire that is from the vaf that goes to the pump relay dont get pluged in then the vaf is geting the wrong reading because of no relay. do you know if the relay should have a constant power to it?
i honestly dont know for sure, but do you know if the pump even works at all? im saying to just put a 12v supply to the pump to test it to make sure it even works
sponsered by,
its only supposed to run when the engine is being crancked over and or running.
sponsered by,
try to get a diagram and go from there..there are some on here or in the back of the Haynes manual. Good Luck!
