ok when i did my enging swap i had the same problem. try setting the idle adjuatment a bit higher on the throttlebody, and make sure there are no intake leaks. also see if the air idle control on the intake is working( mine you can hear when you turn the key on). try those and hopefully it will work. i watched the vid and it sounds like it is being choked out and not running out of fuel. send me a pm and let me know if any of this works.
harness problem
88 festiva lx, 2.3 turbo rwd swap in progress
1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
03' gt, full termi swap 700+ whp build
sponsered by,
pam pam's junk, dayton OR.
Bob's ok tires, salem OR.
Clausen Truckin', keizer OR.
