I have a 93 GL automatic with air. When I turn it on I can't hear the compressor start and the RPM's don't drop. When I pulled the filler cap and hit the tiny button it is pressurized. Can anybody direct me to what to check next? I have to get this working to make it a daily driver to haul my 2 little girls. thanks
A/C help
I assume it worked before? If it's still holding pressure I will assume it's got plenty of freon. It's then gotta be electrical.
Did you check your fuses?
If you did that, check all the connections inside and ouside the car. Might be time to break out the multi-meter and check the relays as well.
Post back with your findings. BTW, I'm no expert here but I've been fooling with my festy's A/C long enough that I can install and troubleshoot it in my sleep.
88 LX - Twin turbo, Intercooled :p
Recently re-chistened from "Cheapstiva" to "Expenstiva"
Look at the relay behind the drivers headlight mine got upside down and held water bc of the little boot that is supposed to keep it dry.-Greg
Redneck Engineer
FOTY - '09
YesOriginally posted by boostmaster View PostI assume it worked before?
I looked and no fuse in the small drivers side fusebox is labled A.C. and the 3 fusible links aren't it either. Are there more?Originally posted by boostmaster View PostIf it's still holding pressure I will assume it's got plenty of freon. It's then gotta be electrical. Did you check your fuses?
where are the relays?Originally posted by boostmaster View PostIf you did that, check all the connections inside and ouside the car. Might be time to break out the multi-meter and check the relays as well.
Count on it! That's why I asked. THANKS for responding!Originally posted by boostmaster View PostPost back with your findings. BTW, I'm no expert here but I've been fooling with my festy's A/C long enough that I can install and troubleshoot it in my sleep.
Thanks! I'll check that next.Originally posted by eurotiva View PostLook at the relay behind the drivers headlight mine got upside down and held water bc of the little boot that is supposed to keep it dry.youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
There's a 20 amp fuse in the panel which I think is marked for the cooling fan. Mine burnt out due to a fan gone bad and discovered that the A/C compressor is on the same circuit.
Hope that helps!Last edited by fastivaca; 07-16-2009, 09:10 PM.Ian
there are 2 relays up there they are the same. swap them and see-Greg
Redneck Engineer
FOTY - '09
Auto has three relays... the third one is for the condensor fan.Originally posted by eurotiva View Postthere are 2 relays up there they are the same. swap them and seeIan
BTW the light on the AC button does come on when it is pushed in and the fan is on. The fan works and the heat works.youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
Those are the ones.Ian
Try a test light on the wire that goes to the compresser clutch.-Greg
Redneck Engineer
FOTY - '09
