I have a 91 Festiva GL. The blower motor works fine when venting out thru panel. However, I am getting not getting any air out thru heater ducts or the defrost no matter what setting I have fan on. I hear the fan running but no air. Any ideas? Thanks. Also, I recently put head gasket/block sealent in the radiator. Not sure if there is connection or not.
No air thru heater vents or defrost.
That radiatior fix stuff can clog a heater core. No heat comes from the dash vents anyways, only defrost and floor.....the way festiva were designed. I'd check for blockage in your ducting....like mouse nest...or clogged heater core---------------------------------------------------
Thanks for reply. I know no heat goes thru dash. I only mentioned that to show blower fan is working. I will check for blocked duct. A clogged heater core would cause heater to blow cold instead of hot. Correct?kned33
91 blue Festiva GL (totaled)
88 white Festiva L (sold)
91 blue Festiva L (sold)
yes....no air through the defrost and floor sounds like a air duct blockage."FLTG4LIFE" @FINALLEVEL , "PBH"
OR a broken linkageTrees aren't kind to me...
Thanks for your replies. I think maybe it was operator error. If the lever is at the coldest setting no air goes thru heater/defrost ducts. I did check for clogs found none but after fiddling around, the heater worked properly. After I moved lever to coldest setting it didn't. I moved it over into the red zone and it worked fine again.
I've have festiva's for years but never realized what I just learned. I feel a little silly though.
Thanks again.kned33
