i got some questions about some problems i have with my festy and wanted to ask you guys what you though and maybe we can fix it ... to start with my a/c ... it looks like it was not professionally installed ... however the air is cold but the fan will not blow ... when i have the a/c button pressed in and i go to turn the fan on .. my car will lose rpms ... almost to a stall but nothing blows out the a/c vents or even sounds like anything will blow ... and it turns my fan on and when i turn the a/c fan switch back to the off position the radiator fan stops spinning and the rpms go back to normal ... and i know the air is cold because if you sit there long enough you can feel cold air barely coming out... what could be the cause of this?i have attached some files showing some of the wires...and a pic of my car since i haven't posted any yet hehe.
this relay is on the passenger side at the back corner
this relay is behind the driver side headlight with the connections underneath
this is a picture of one of the wires going from the relay behind the headlight (dr side) to something i don't know what it is ... sorry i am not very mechanically inclined.
this is a picture of what i think is the compressor ... not sure...but one of the wires from the pass side relay is connected to it ... i couldn't see the connection very well as it is dark and the angle i had to look at it with the flashlight
this picture is the tstat in the car .. .or a/c controls whatever u wanna call it lol
this would be a picture of my festy in the dark ... it is really teal not dark blue ... there are some dings but pretty decent condition other than that .. tis a 93 5spd if that matters
any help will be greatly appreciated ...
another question would be how would i go about getting the dings out?
thanks travis
ps... also when i turn the a/c fan switch on when the rpms drop the car sounds really rough and shakes a bit
thanks travis
