Another member on this forum used the Carter-Weber carb off like an '80 or '81 Ford Escort which was non-computer with 1.6L engine. He posted that it really worked well for him and posted pictures. I already posted here someplace a link where you can buy a BRAND NEW old stock one of these for like $85. Its some guy that bought up a truck load of them cheap and resells them to people wanting to put triple carbs on old straight six American engines. But you can buy just one. Also show up on ebay. Its Weber design licensed by CArter. There are Holley-Webers (Weber design built by Holley) also but they were used on bigger 4cyl and small V6 engines so probably at least would need rejetting for best gas mileage and maybe too big bore for stock Festiva engine.
No kidding about cleaning up engine compartment. I used the Mazda intake manifold that came with my 1.6L and its offset a bit to the drivers side compared to the Festiva manifold. But without all the black spaghetti and other crap, I can now easily get to alternator and oil filter on back of the engine from on top, no more putting Festiva up on jack stands and crawling underneath to change oil filter.
One thing about the Weber or Carter-Weber is that you need an adapter as Festiva and Mazda use unique mount. I didnt find an economical to buy Weber adapter so made my own out of couple pieces of 1/4 inch steel. One to match manifold, one to match carb, then bolted the two plates together. The other member who used Carter-Weber carb had some guy who modified the manifold itself so carb fit directly, but few of us are so lucky to have cheap access to somebody that can do such miracles with aluminum. My steel adapter plates just took some of my time to shape, the materials were out of my scrap pile.
Though that place where I found pic only wants $159. Wait it might not be feedback, the older Japanese carbs had fuel shutoff solenoid that screwed into the carb, that might be what the wires go to. Feedback carbs usually have throttle position sensor. and the little motor thingie that adjusts jets. So this might be a possibility for somebody needing to look factory original. Festiva air cleaner might even fit it.
See the throttle position sensor?
