What is the correct oil viscosity for the b3 efi engine
  • What is the correct oil viscosity for the b3 efi engine
    What is the correct oil viscosity for the b3 efi engine. The temperature here is 30 degrees Celsius. It's the middle of the summer.
    Thanks
    :festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
    10w30
    - Unknown
    - Quentin Crisp
    - Bumper Sticker
      how is the climate in Malta??
        I asked for the oil viscosity because, recently the engine started to make a ticking noise. I think it's a hydraulic lifter. A few weeks ago, I added 2 different types of oil in the engine because they were in the garage & I wanted to use them. One was 15w-40 and the other was 20w-50. Could it be the fault?
        Thanks
          I wouldnt think the 15w40 would be a problem. But the 20w50 is just a tad on the thick side even for your climate.
          - Unknown
          - Quentin Crisp
          - Bumper Sticker
            I would go with 10w40
              I've run 100% 20W-50 in the summer in Georgia without problems.
              I'm more concerned about the 15w-40, which sounds like a diesel oil to me.
              Not so much about the viscosity but formulation is for a diesel engine not a gasoline engine.
              Diesels need different oil formulations due to different issues that may not play all that well with gasoline engine formulations.
                Diesel oils are usually rated for gas engines too, in fact they are usually better (or even REQUIRED) for older engines with slider cams that need zddp. Im running rotella t synthetic in everything I have right now.
                91GL BP/F3A with boost
                  agreed^^^
                  i am running Rotella synthetic 5W40
                  I am the original
                    Straight 30w in summer, and 10w30 in winter. I have been known to use 20w50 in summer cause they dont always have 30w in the 5qt bottles (little cheaper than buying quart bottles). No problem with it.
