Passive Restraint System
  • Passive Restraint System
    I have an Idea what it is but I want to bounce it off you guys.
    When Driving down the road the drivers seat belt moves like it started to retract and then came back to lock, actual movement is about a 1/4th of an inch
    My first thought is door switch because there are times when you open the door and the belt does not retract for several seconds or not at all - and sometimes if you shut the door and open it again the belt works correctly.
    I'm leaning away from motor since the actual movement is fine, could it be the seatbelt controller? The passenger side does not move once its in place. My seatbelt light has come on and stayed on durring opperation since this started.
    92 GL - parts car
    97 aspire - parts car
    87 323 DX - daily driver
    check the door switch? idk tho.
    -Greg
    Redneck Engineer
    FOTY - '09
      well its not the striker switch - I'll try the motor here shortly - I also swapped back in my old belt that I know are good so its not any of the belts either
      92 GL - parts car
        The more problems i hear of with the auto belts the happier i am that canadian festivas never got them :lol:
          Neither one of my belts reel themselves in. If I don't want them laying on the floor or hanging out the door, I have to manually stuff them back into the side panel. Minor set back, but hey, its 20 years old, and worn out I suppose.
          My Fleet:
            Which belts do you need? PM me your details I have a full set I can send you
            92 GL - parts car
