I have an Idea what it is but I want to bounce it off you guys.
When Driving down the road the drivers seat belt moves like it started to retract and then came back to lock, actual movement is about a 1/4th of an inch
My first thought is door switch because there are times when you open the door and the belt does not retract for several seconds or not at all - and sometimes if you shut the door and open it again the belt works correctly.
I'm leaning away from motor since the actual movement is fine, could it be the seatbelt controller? The passenger side does not move once its in place. My seatbelt light has come on and stayed on durring opperation since this started.
