drives fine,then slows and goes slower....??
  • drives fine,then slows and goes slower....??
    ok,here is what it is doing..You go down the road(hwy speeds) drives fine,then all-of-the-sudden it slows.You can floor it and it stays the slow speed it went down to,or it goes even slower.Then eventually it gets back up to speed.Now,I got it home,left it running and opened the hood.I manually pulled the cable and it started to slow.Then I pulled it all the way open(1990 auto EFI engine,by the way)and it slowed,when I go to let it go or release it a little it revs back up ???????????? I trust none of the F*&^%$ mechanics around here,so,I come to the pros...you all.
    Throttle Position Sensor perhaps not giving it enough fuel
    92 GL - parts car
    97 aspire - parts car
    87 323 DX - daily driver
      where is that ? pic ?
        Little black plastic box to the right of the throttle intake.
        Looking for pic now.
          Two 8 or 6mm cant remember screws to take it out - you will have to tug on it slightly to make it pop off; just dont twist on it. it comes straight off towards the passenger side
          92 GL - parts car
            um mean drivers side
              Tunner is the man with the answers tonight, or should I say pics!
                well I havnt left work yet (off the clock though) just using the fast internet and my car is right 15 foot from my door
                92 GL - parts car
                  Originally posted by Festiva_tunner View Post
                  well I havnt left work yet (off the clock though) just using the fast internet and my car is right 15 foot from the my door
                  And you happen to have a camera at work!
                  I need to work there!
                    its provided with the job
                    92 GL - parts car
                      Could also be the elusive fuel filter. I know it's more of a problem on carb'd motors, but you're definitely not getting enough fuel one way or another.
                      -Caleb
                      Originally posted by cracked.com on the M203 w/ M433 HEDP
                      So, for about the same price as a fully-loaded 1993 Ford Festiva, you could also wield the power to obliterate a small village in the blink of an eye.
                        I will pull fuel pump and sensor tomorrow from parts car.I did have the fuel filter replaced,though.
                          I would try the TPS before the fuel filter then if you've already replaced the canister filter
                          92 GL - parts car
                            Sounds like you guys need turbos LOL
                            -Greg
                            Redneck Engineer
                            FOTY - '09
                              I would say you are loosing fuel pressure I have worked on tons of cars with like problems and 9 times out of 10 its the fuel pump or pressure regulator. You can unplug the TPS and the computer will go into default mode it wont accel correctly but you can drive it and see if it still dies. Also may be a kink in a fuel line I had a caravan I worked on been to 3 or so mechanics charged the guy a ton of money and all it needed was a new rubber hose on the return side couldnt return fuel so it would overload and lose all power only would idle hope this helps
