yeah, he couldn't meet his quotas (poor guy).
drives fine,then slows and goes slower....??
Originally posted by TONYCASH View Posthere is what happens.Sometimes you will be going 65-70 and the car will be normal.Then all of a sudden it slows.you press the gas,but,it doesn't matter.it slows down,but,stays steady at what ever speed it went down to,say 55.then in a few seconds it comes right back up.It is like when you push the gas peddle it wants to go even slower(bogs down). then , at other times,you'll be sitting at a stop sign or light.you go to take off and it stalls.if you baby the throttle it sometimes doesn't do it.And another scenario is when I back out of drive(happened twice) I put it in gear ( automatic) and start to go and it stalls.In the stalling scenarios it won't start back up.Let it sit and it does , mostly,after a bit.Sometimes 5 mins sometimes half hour.
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
Originally posted by Festiva_tunner View Postthis makes me wonder about your torque converter"FLTG4LIFE" @FINALLEVEL , "PBH"
Originally posted by GenevaDirt View Postwhat does the torque converter have to do with it running while it is parked and hitting the gas? It stalls while in park.
92 GL - parts car
^^Unbolt the exhaust and go for a LOUD drive :evil4:
Originally posted by Damkid View PostUnbolt the exhaust and go for a LOUD drive :evil4:and I have :evil4:
-Caleb
Originally posted by cracked.com on the M203 w/ M433 HEDPSo, for about the same price as a fully-loaded 1993 Ford Festiva, you could also wield the power to obliterate a small village in the blink of an eye.
Originally posted by 25Horseplay View PostCat convertor plugged?Trees aren't kind to me...
OK...I still have not had it looked at and the problem is still there.I think I should take it to Ford,but,you all might have a better idea ? Any REAL mechanics close to me to take it to ? I need it fixed only because it is moms and she wants to take it to Florida next month.If it were mine , well, I wouldn't be so pressed about it.
Maybe I should tow it to Ohiostiva next week...???I can.
If it were me i would loosen the radiator brackets at the top. Unclip the wiring harness that is under the top of the radiator support that runs over to the VAF meter.
There are 7 wires in that bundle (all black in color), one of them is a shielded wire if there is a fray in the outside layer and it has rubbed through grounding out on the car that could give you your stalling problem. It may have a bare spot on it and it is getting interference from another wire. That is my assumption since everyone has listed everything else.
So just look the wiring over before your swap an entire intake manifold to find out that the problem is still there.Last edited by festivaWES; 09-14-2009, 10:10 PM.---------------------------------------------------
