stock 91 efi GL auto
ok i got this car and it had no breaks well it did when they to the floor and barely work. but when the car is off it will build some pressure. i took the calipers off new pads cleaned the calipers and got every thing working, but now the arnt getting any fluid or build pressure when they are off. only thing i could think of would be the rubber hoses collapsed but then they still should pump up but they dont so maybe would it be the booster of master cylinder is bad? what do you guys think
