break prob
  • break prob
    stock 91 efi GL auto
    ok i got this car and it had no breaks well it did when they to the floor and barely work. but when the car is off it will build some pressure. i took the calipers off new pads cleaned the calipers and got every thing working, but now the arnt getting any fluid or build pressure when they are off. only thing i could think of would be the rubber hoses collapsed but then they still should pump up but they dont so maybe would it be the booster of master cylinder is bad? what do you guys think
    Hate to be the one to ask the dumb questions, but have you check your brake fluid and/or bled the brakes. Possible brake master cylinder as well.
    -Caleb
    Originally posted by cracked.com on the M203 w/ M433 HEDP
    So, for about the same price as a fully-loaded 1993 Ford Festiva, you could also wield the power to obliterate a small village in the blink of an eye.
      haha yeah its full of fluid and i tried to bleed them and nuthin
        As in nothing came out? or no air came out?
        -Caleb
          my thoughts are air in the lines, or bad master cylinder....if you pump your brakes when car is on and it builds pressure its the master cylinder....same happend to my tahoe ...swapped the master cylinder and it fixed the prob....also when you bleed the brakes you have to start farthest from the cylinder and work your way towards it...so probably rear pass,then rear driver side,then front pass,then driverside front....if you dont do it in that order air can stay in the line.
          ADMIN @ http://ironjuggernauts.com/forum.php?referrerid=1
            I've had 3 masters go bad on me and it sounds like thats your problem
              i know how to bleed the breaks i went to a school and took auto tech and my dads a mechanic so i know. but if i didnt mess with the back then no need to bleed. and i was just seening if what i think is what you guys think so i dont fix it and it didnt really fix it you know what i mean. and yeah no fluid no air nuthin.
                I'd say your master cylinder is by-passing internally.
                If you put another one on, don't forget to bench bleed it.
                  yeah i figured i would have to do that. i dont know how to do that tho
