LCA/ball joint replacement
  • #31
    ^^LMAO Lets not get into your sex life!
    • #32
      Or yours for that matter!
      - Unknown
      - Quentin Crisp
      - Bumper Sticker
      • #33
        LOL mine seems DEAD right now!..............honestly
        • #34
          Well if it makes you feel any better(which it probably won't), mines about dead as well.
          - Unknown
          - Quentin Crisp
          - Bumper Sticker
          • #35
            Actaully it does. Thank you. My how this thread has progressed!!
            • #36
              Is there some connection between "sex life" and "lower control arms" I'm not getting? ;-)
              • #37
                No not really. But Wes started it when he said he was fast at everything. :p
                - Unknown
                - Quentin Crisp
                - Bumper Sticker
                • #38
                  Originally posted by festivaWES View Post
                  5 minutes come on.?? I can't even finish a bowel movement in that time and I'm fast at everything!
                  Its 3 bolts... lol It took me 5 mins. I'm no amateur. Plus i'm a tech. Its what I do.
                  • #39
                    Lower Control Arm and male members.. I can't see where the sex life connection came from.
                    • #40
                      ^ lower control arm.... that's all i have to say.
                      • #41
                        Actually its 2 bolts and two nuts, but who's counting!
                        • #42
                          Need to keep eye on tie rod ends and ball joints, if dust boot goes, the joint wont last very long. You can drill hole (magnetize the drill bit by rubbing it across a magnet) and use self tapping zerk to make it greasable. Look in auto parts store for universal polyurethane dust boots, they last forever. If you catch boot problems soon enough you can save money. If joints already loose, replace them.
                          Once joints get loose, they self destruct quickly. On my old F250, knew I needed to replace drag link and tie rod ends. Even ordered parts from RockAuto, hadnt installed them. Then I had to drive it significant distance to pick up couple Ford 300 engines I bought so figured I should at least grease the front end. End on drag link was about ready to just fall apart. I replaced everything and boy the steering really became lot tighter and more controllable. All replacement joints seem to use crappy dust boots. Need to keep eye on them and replace with polyurethane when I notice any tears.
                          • #43
                            I need to replace my control arms as well. This is just the thread I needed. Thank You!
                            On my 2nd Festiva and regret getting rid of the first...Long live the cult of the Festiva!
